chevalier
I have come across a project that uses a lot of opaque white ink screens as an effect on a metallic substrate. I realize that once we get on press we're going to almost certainly need to perform some dot gain calculations and generate curved opaque white plates.
I'm thinking that if I invert my measurement differences that I'll be able to achieve this. I would like to note that I do realize that the screens themselves aren't actually inverted. A 20% screen of white is effectively the same as a 80% print of metallic in theory (the screening being inverted in this measurement case). Upon measuring a control mark and seeing 85% then I would be printing 5 points sharp (dot loss) and that if I see a 75% I'm gaining 5 points (dot gain).
I'm lucky enough to have a calibrated Xrite Platescope XRD60 (https://www.xrite.com/platescope) that has been verified to a proof on substate (Fujifilm Finalproof) to at least give readings on the substate at least exhibit what I'm theorizing above. I tested with all the available spectrums: Red, Green, Blue, RGB ("White"), UV and Infrared and Red seems to provide the most sound and consistent results. I also have an i1Pro2 and eXact but I've found the quick down and dirty dot gain calculations for spot colors are generally easier with the XRD60.
Am I on the right track or have I lost my mind?
