Anyone have this happen to their screen on their cutter? This has been progressively getting worse over the past 3 months or so I guess - started as a couple distinct deletion lines, now about a dozen. The only thing I’ve thought to try is power off / disconnect and reconnect, which I did. This cutter gets powered down every day so I’m surprised the screen is getting worse this quickly. Not sure if this is something we can fix, if it’s the screen itself or a different electronic problem, or if we need to replace the whole microcut panel (how feasible is that?). Attached to a very old challenge cutter, which otherwise works fine, replacing the whole cutter wouldn’t be ideal.
