Gregg
I recently had a thread about images being compressed within Acrobat.
http://printplanet.com/forums/adobe/32010-how-do-you-prevent-acrobat-x-compressing-imagery
Since then, I've accepted the fact that Acrobat is going to compress my images when I save and there is nothing I can do about it. However, Acrobat is not consistent, and I am trying to figure out why.
Examples where compression IS NOT applied upon saving:
• I have a multi-page PDF with numerous 400dpi grayscale images and text. The images are 100% of original size (no compression). I change my Properties so that the initial view is Fit To Page, this requires a save, which I do (File - Save). I re-open the PDF and the images are still 100% of original size.
• Using that same PDF, I delete some artwork and some text (using Pitstop). This requires a save, which I do (File - Save). I re-open the PDF and the images are still 100% of original size.
Examples where compression IS applied upon saving:
• Using that same PDF, I replace one of the pages (the copyright page) with a revised copyright page - this page is text only. This requires a save, which I do (File - Save). I re-open the PDF and all the images now have been compressed using ZIP compression.
I understand that ZIP compression is Lossless and I shouldn't be concerned that they are compressed, but why did it compress my images with one action and not compress them with the other actions?
