NCR. middle sheet ok to use as bottom sheet?
BigSi
Hi there,
The title says it all. I can't see any reason why I can't use the middle sheet (CFB) as a replacement for the bottom sheet (CF) when I have to.
I realise CFB is more expensive, it's just that some time I run out a specific colour in CF (carbon front) and it would be very handy to make up the shortfall with the correct colour using CFB (carbon front and back) if I have it on the shelf.
Your thoughts?
thanks Simon
Hi there,
Your thoughts?
thanks Simon
The CF coating is identical whether it's on a CF or a CFB sheet, so this will work in the absence of another CF coated sheet.
Yes, but if your using it as a replacement for the bottom sheet it won't matter as there is a writing shield anyway, Probably not a good idea to use as a replacement for the top sheet.
(might affect the ability to write on with carbon on the top). ta Simon
