Need help with Speedsetter Xante VM4
ChrisZ
Hello.
I need help with machine as in topic.
Second hand, not used for some time. History unknown.
The issue:
Image start in speedscan direction is 16cm from plate edge.
In service menu I can adjust that +/- 2cm.
I suspect, that spinner was replaced for unknown reason.
No way to rotate spinner, there is stop pin to lock it in correct position.
Air bearing spinner Axsys 133.136RPM.
Anyone can help? Share service manual? In mine there is nothing about adjusting FS image start position.
Thanks, Chris
