Neo scaling and line weight
Mutz
Hello
When i draw a line or circle and give it let's say 4 pt width, then use the transformation palette to scale or change the dimensions. Then the line weight scales too. Any way to just lock the line weight when scaling or changing dimensions? When you changed the width of the object the line width scales too so you have a box with 2 different line weights... you can't just fill in the correct line weight again the scale sticks...
ty
