prepress@labels
We send Illustrator CS3 files to a RIPit system (OpenRIP Flexo 6.0) and output them to an Epson proofer, and also to a PDF.
Once approved, the file gets dragged to a print queue for film output.
We select "Do Not Print" for the dieline color so it doesn't output.
This works great, except in a few cases where we see trapping effects produced by the dieline. The dieline is set to overprint, and the dieline color is switched to "Do Not Print" in the RIPit system, but we still see trapping effects from the phantom dieline which show up on film.
I've tried a variety of colors for the dieline trying to avoid trapping with the same results, and I've tried playing with different trapping settings (Spread, Choke, etc.) which produce varying trapping results but never eliminate the problem.
To summarize: the dieline color, set to overprint in the Illustrator file, should not produce any trapping effects, yet it does. At this point we have to either create 2 files (Print-ready and Proof) or delete the dieline in Illlustrator and resend.
We're doing option 1 now, creating 2 files on the same page, one with and one without the dieline. This is clumsy and must be explained to clients.
Option 2 is not really an option because re-outputting files after getting the file approved defeats the purpose of proofing at the RIP.
Any suggestions?
Any suggestions?
