PackEdge cursor won't change
Brad38CMU
I'm having an issue with the cursor in PackEdge. When I switch from the selection tool to the zoom or pan tool, the 'hand' or 'zoom' icons won't change back to a 'pointer' when I switch back to the selection tool. Anyone else run across this?!
The only solution I've found is to re-launch PackEdge, which is not practical. Please help!
Hi
I had that problem using Packedge 5 and to go back to another tool I used to click into another tool in the toolbox (not using shortcuts).. I used to click several times until I got the one I was looking for..
Cheers
Marcelo
Hehe, I had the same problem.
I finally got used to use the "hand" as pointer when needed. Hadn't too much time for think on it because of the tight deadlines :rolleyes:
