I work for a check printing company so I'm dealing with thin line pantographs a lot. I always find the final result disappoint because the detail of the pantograph is lost due to the loss of the solid line with a screened line with offset press printing. I'm curious if anyone has messed with going to a thinner line stroke as a with no screen for a solid line instead of a thicker stroke that is screened whether it be with Illustrator or any of the equivalent layout programs.
Since most of the designs aren't straight lines switching from a dot screen to a line screen doesn't help as much especially when the screen are in the 15-20% range. Thinner solid lines to emulate a similar screen value would also allow for microprint lines within the pantograph and not lose all the detail in the small text.
