Exactly. Do you know why that happen?I can spot a difference - Preview will often display that pesky box behind live transparency effects while at the same time Acrobat displays correctly (no pesky box).
Nicolas
The simple answer is that pdfs do not display themselves, that is they do not contain an internal display application. Rather, their display is dependent on other applications having the capacity to display these files. So whatever differences you are seeing reflect differences between these applications.
A better answer requires a better question. That said, specifically what sort differences are you noticing?
Al
Hey, AI
Thanks for you answer. It is so slow upload the image but just as LoneGoose said there is a pesky box behind object I applied drop shadow to it. However, that doesnt exist in Acrobat.
Is it only showing on your RIP preview or is it showing on your output / plates? PDF's sometimes show artifacts like that at your display but do not produce on your output. As to "why", might need an Adobe engineer to step in and cover that one....
On the contrary! We need to hold Adobe's feet to the fire for the Professional versions, so that what we see on our Acrobat Professional displays, matches what "pdf compliant rips" produce. If the RIP is leaving something unprocessed, then we go after the RIP manufacturer. BUT if Acrobat Professional leaves off something that the rips do correctly process, then we have to keep on Adobe's case about it.Thanks your answer. It just show on the preview. Okay, stop asking why haha
In view of the fact that Acrobat X/10.0 was released only a few days ago, it would be appropriate for you to add some brief comments as to the improvements in this new release that you you think may bear on the OP's superficial description of the problem he is experiencing.
l
If I export a PDF from Indesign, or Photoshop; Then, I use different PDF viewer to check it, such as Preview, Acrobat Pro, and Prinergy VPS, I get some different display results between them.
Questions:
1, why that happen?
2, Is it involved any RIP issue?
One thing I have found causing confusion due to different/unreliable page display when using Adobe Reader, is "Overprint Preview" setting. To avoid any such mistakes, I always instruct customers (and tell them to instruct *their* customers) to set Adobe Reader "Preferences - Page Display - Use Overprint Preview" to 'Always'.
If this is off, Adobe Reader will display certain transparencies (A drop shadow being a prime example!) incorrectly - i.e. differently from what an Adobe compliant rip would produce.
