Hello all,
Hoping for some advise, experiences and/or opinions. Any and all input will be appreciated.
General information:
•We have a one year old 40” 4/c Komori H-UV perfecting press. We are G7 certified.
•We do not linearize our plates, they are no more than 2% off target at the 50% as is.
•We have been using Fuji ColorPath to create plate curves with varying degrees of success.
•We use the G7 Form IO_v20155b 28x40 form for our press runs for creating plate curves.
•We measure the P2P charts printed on that press form printed at house densities.
•We then create generic plate curves for both coated and uncoated paper (generic meaning paper).
After the initial press run and a number of iterations (usually 2) we have a new set(s) of plate curve data which we apply to our workflow (Esko AE, IE).
The curves are applied as a strategy, the data measured from units 5-8 from the P2P chart is applied as compensation curves to both units 5-8 and units1-4.
The questions are as follows;
1) As we do iterations the overall appearence of the press sheet improves, but we notice that as we progress we are noticebly red in quarter and mid-tones. Why? ColorPath is supposed to achieve grey balance.
2) Are we expecting to much? Should we iterate only until we are “ballpark” and achieve the desired result on press? After a point, after many (4) iterations, we lose too much dot gain and control on press.
So obviously we do not use the last iteration. This is despite the “best” result on the test form.
3) Should we create a single generic plate curve first (meaning dot gain, averaged per unit) and then use
ColorPath just for optimizing the once generic curves?
4) We are looking at implementing ink optimization (currently testing different offerings). What is your
experience as far as true ink savings, ease of implementation, ease or improvement in printing and gray balance?
