Hi Gordo, nice survey
I have voted the second option, however this is not really true and I would like to clarify. - I prefer to use the term "set of curves", each curve attached to an ink because not every unit (same press) print exactly the same way. And then, we use a "set of curves" for each combination of press and substrate. This is a typical example: if we had two different presses (A and B), we will end up with 10 different "set of curves".
- Heatset Web Offset Press A - Gloss Coated
- Heatset Web Offset Press A - Matte Coated
- Heatset Web Offset Press A - Improved/Standard Gloss Coated (LWC)
- Heatset Web Offset Press A - Machine finished coated (MFC)
- Heatset Web Offset Press A - Uncoated White Offset
- Heatset Web Offset Press A - Super calandered (SC)
- Heatset Web Offset Press A - Standard Newsprint (SNP)
- Sheetfed Offset Press B - Gloss Coated
- Sheetfed Offset Press B - Matte Coated
- Sheetfed Offset Press B - Uncoated White Offset
regards,
ferran
