Points in Illustrator
You can have the count of all the anchor point in a document by choosing the Document Info Panel, make sure you uncheck the Selection Only in the Panel option and choose Objects.
To expand a little on jct's answer:
1. Select "Document Info" from the "Window" drop down menu (see Untitled-1.jpg)
2. Do a "Select All"
3. Select "Objects" from the drop down menu on the "Document Info" pallette (see Untitled-2.jpg)
4. This will give you the total amount of points in the document
