It's better to Upgrade to v10. And indeed if you have an License you can install it. Just make sure you have enough concurrent user licenses to run it simultaneously with other users at the same timeDoes anyone know if there is a Workshop Client available for Prinergy 8.3 on the PC and will it run on the newer versions of Windows? Thank you!
Thanks! I'll have to check it out!The client should be in the WkspInstall share on your Prinergy server
