YNOT
Hello all, first time here and I'm looking for advise regarding multi-upping a file from printshop mail 6.1 4-up to 12x18
Unfortunately my knowledge level with printshop mail is very limited and thought to ask the experts as to what you thoughts were on how to make this work more efficiently.
The file is already setup 1-up and the multi-upping is being done at the ripping stage, the problem is that the PDF used in the setups is 7meg. I suspect that this would cause it to slow down
Any questions you may have, I will do my best to answer. By the way, the file record count is 5,200 records and I'm ripping it every 2,000 records locally instead of the printer right now and is running very slow.
Thanks in advance
Thanks in advance
