processless plates agfa azura TE V fUJI PROCESSLESS
sceptical munro
HI MY CUSTOMER IS USING Fuji PROCESSLESS PLATES SUPERIA ZP , on screen plate 800 platesetter , the plates work ok ,
But when we put in the AGFA Azura TE PLATE it doesn't work ? , there are some noises and clunking sounds coming from the platesetter and we
end up taking the plates out without being imaged , I suppose we need to get a technician there to recalibrate for the Azura TE plate ??
If I remember Screen CtP correctly, you have to calibrate those sensors on the back of the machine for different color of plate. There should be left and right one. They read the plate position before punching. If they don't read plate correctly, machine tries multiple times to move plate back and forth. In that case, plate can hit back of sensor and make whole machine malfunction. If plate is ejected without being punched, I guess it would be the case.
