Here's what I'd consider a much more concise answer:
Every device that reproduces color reproduces it to some degree differently. A profile is a description of how a particular device reproduces color in a certain calibrated state.
And the two things to keep in mind about any profile are that whatever the limits of a particular profile, they are the limits you apply to the device you're using it to drive every time you use it; and, the closer the profile you use matches how the device you're driving it with actually prints, the more you'll get predictable results.
You said you were large-format and offset.
At present, those two arenas are traveling in somewhat divergent paths regarding color in general. In offset, there's a tendency to define process ink values to standards for chroma and density. Then if a press can be linearized--by whatever means, such as G7--theoretically there's no need for a specific profile for any press. One size fits all...
Yay! Printing as a commodity.
In large format, the straitjacket is still at least in the other room. It's pretty much imperative if you want to get full capability out of a large-format workflow that you profile each printer on each media in your specific environment.
And if you want to learn how to do it correctly, it'd be very beneficial to hire someone to come in and set this all up for you.
Mike Adams
Correct Color
It seems that the bigest problem this poster has is the untagged CMYK images and how to handle them.
New to Color Management and our files man uses a default profile(US Web Coated(SWOP)v2) This seems to be working fine. Can someone breifly explaine Profiles and why would you make your own?
Oh?
Maybe it's just me, but I'd say he wanted a brief explanation of profiles and a reason for making custom profiles.
I also agree that if a press can be linearized, however each and every press needs to be linearized and I would suggest two processes one for the house coated and one for the house uncoated stock. I wouldn't call it printing as a commodity I wouls call it practical linearization. At the cost of a days production making a linearization curve for each and every media is IMO BS.
Now to this gentlemans issue once the presses are set up they can actually use any CMYK ICC profile that has a TIC equal to or (and I stress slightly less then the linearization curve of the press.
Ok the process starts with choosing an ink set, paper, blankets, packing materials and making sure the press is in good working order, I've gone on site and spent three days with a press repairman before anything could start.
On the plate setter you run a test pattern, it differs with different manufacturers but the concept is to get the plate setter running screens of the propper percentages, 5%, to 100%
some system have a 3% they start with. Once the setter is linearized (producing the propper screen percentages) the plates are taken to the press and printed to the propper ink density based on the ink manufactureres specifications. The test pattern is read and adjustments are made inthe plate setters command software to adjust for dot changes. A set of plates are made with these changes and the test run again and read.
This creates an ink limits, linearization dot gain curve for maximum gamut from the press with the specific media and ink set.
Yes it's a two step process, the plate setter needs lineraized, then the test is printed and press sheets read for press dot gain or dot reduction. The plate setter is then adjusted so the (for example) if the setter placed a 50% dot and the press printed 52% the curve reflects that so that the plate curve is moved, so that when the ink density is hit the new dot produces 50%.
I've asked this in another thread. Is your idea to have a 50% tone in the original file print as a 50% tone on the press sheet.
thx, gordo
