Albert Noel
after over 10 years of using the same powder, we've come into far too many issues lately and decided to try out different slightly larger size powder. we've decided to move from a 25-30 micron to a 30-35 size.
our roland 300 has a graphix hitronic S unit and the throat at the "hopper" for the powder has a choke setting. ranges from .01 .02 .03 up to .10 ect. it's always been set at .02 since it was installed (we've always used the 25-30 powder) and im just curious if that setting changes in relation to how fine the powder is? i can only assume so.
since we are moving to a 30-35 micron power, do i need to change it to .03mm to work correctly?
as stated previously, we've only ever had it on that same setting for the last 10 years using that same powder.
this may be a stupid question, but im unsure and i want to avoid clogging and/or reruns
