pressmanken
We have an older model Ripit Imagesetter that is producing random imaged vertical lines at different locations on the plates. They are about 1-2 inches long and usually appear near the lead edge of the plates. Many times I can e-image the plate and the line will not reappear. Other times, I have to re-burn several times until I get a clean plate. I suspect the laser is somehow causing this, but am not sure how. It doesn't seem to be dust, as it doesn't run horizontally across the plate from margin to margin.
