Rasterizing Vector and getting inconsistent color
Gregg
I recently had to rasterize some extremely complex AI files. Originally, I had rasterized (opening AI file in PS) to CMYK. The resulting color was pretty far off. Then I rasterized to RGB and once in PS I converted to CMYK. The resulting color was much better.
What I can't figure out is why that method worked better.
My Creative Suite color settings are synced:
Adobe RGB
ISO Coated V2 300% (ECI)
Relative Colorimetric
Am I overlooking something simple, or is it a more complex explanation as to why going:
RGB AI - CMYK PS = no good
RGB AI - RGB PS - CMYK PS = good
Thanks in advance for any feedback.
I'm going to guess that when you brought the file in to Pshop in RGB and then converted, you used conversion settings that differ from your Color Settings. If you bring the RGB file in as CMYK, Pshop has to use your Color Settings for conversion. I'd have to go through the steps with you to be certain.
When I tried it, the two were close, but not exactly the same. Then I changed up my Color Settings and tried it again; this file was not so similar to the first one. And, it shouldn't have been.
All settings are the same. Same working spaces and same rendering intent.
Could it be overprint/transparency settings being double applied? This is one that snags us every once in a while in Illustrator for both vectors and rasters, process or spot.
I should probably elaborate on this. This is not intended to be a thread hijack.
Simply put, an object in illustrator assigned transparency: multiply and fill: overprint will cause problems but it gets way more complex than that and this is what I am going to explain. This can be maddening when going to a RIP but typically occurred upon generating a PDF. This is possibly a very confusing explanation but it's the best that I can do. I'll post a screen recording if requested.
Illustrator treats layers/sublayers/objects basically the same. It's a little known feature and rarely used on purpose. The typical use is accidental and occurs when using the Layers panel "Select all objects on layer" button (the circle at the right side of a layer label). It's a quick way to select only the objects on a layer but instead of selecting the objects like a selection drag with the selection tool (Black pointer) it actually selects the layer. Thus when you apply transparency effects or overprint settings with this selection technique the effect/setting is not being applied at the object level but at the layer level. If you select just the layer in the layer panel you won't see the transparency and overprint. You'll only see if you use the "Select all objects on layer" button (the circle at the right side of a layer label). This also allows you (why!?!?!) to assign effects/settings on the sublayer, group, subgroup and object levels creating a dual effect/setting.
Therefore, an object can actually have per level transparency and overprint settings which can really confuse the hell out of a RIP. I have seen crazy color shifts on objects because of this.
Side note: if you select all, copy/paste and paste into a new document (with or without paste remembers layers enabled) the layer level effects/settings are not carried over which typically eliminates the problem. We used to file this under a "corrupt document" explanation until I finally figured it out.
The first time I finally figured it out the job was a carton produced: Opaque White (2 hits) + CMYK + Varnish + Spot Coating + Emboss. As a believer and practitioner of composite files my press file had a diecut layer, emboss layer, coating layer, varnish layer, trap layer, opaque white layer 1, opaque white layer 2, then various artwork layers. That's 7 layers on top of the document with transparency/overprint settings. The CMYK artwork was shifting upon generation of a PDF as if a Photoshop adjustment layer for curve had been applied at 30% to output 50%. It turned out to be the scenario described above with the Opaque White layers/objects.
