Reasons to not edit images in Acrobat?
supace
Hi folks. I'm new to the forum, so apologies if this is covered somewhere and I haven't found it yet.
Since I am the only person on staff who knows InDesign, my colleagues frequently try to lessen my workload by coming up with "workarounds" — which is to say, ways to "work around" me to get things done. For example, they will edit designed PDFs in Acrobat. They have mostly done this without telling me, but up until now the edits have been to text, so I haven't pushed back too much. The reality is that print production is only 50% of my job and we work with freelance graphic designers who I keep hoping my coworkers will rely on a bit more than they actually do.
Recently, I found out that my coworker, who has only been out of college for a couple of years and has no graphic design experience or training, has decided that it is okay to replace images in PDFs using Acrobat. All my instincts say this is a bad idea, but I don't have hard evidence that this will cause problems with print ready PDFs. Am I correct or am I overreacting? I would love a technical explanation — for or against — this sort of workflow so that I can address the issue with my coworker and her manager.
Thanks in advance,
Susan
We receive customer PDF's created many different ways with many different programs.
We don't have a problem with the STYLE or PROGRAM of creation or edit because we have no control. As you are finding.
We DO have a problem with all types of image quality and missing/locked fonts.
So to resolve the 'image/font' issues we run an internally customized Pitstop report which flags said issues and allows for communication to the customer while giving a reference for correction - or not.
I recommend something similar to achieve some regularity in submission and result - or at the least CYA.
Some issues...
If you edit the customer PDF then you take responsibility if those edits result in issues on press. You also sever the connection between the original application file and its resulting PDF which can then cause problems for the original author if, for example, they use their original PDF for a different project.
IMHO, if you determine there’s a need to alter a customer supplied file then you need to contact the customer and explain the issue and allow them the opportunity to make the changes themselves.
Some issues...
Yes - we work in a communication industry and it is absolutely amazing how we can mangle communication.
A paper trail listing issues, and resolutions with processes that manage expectations and results, is achievable and desirable.
(I believe I managed to not completely mangle the Queens English in my previous, long, sentence. ;-)
It could be worse, they could be editing PDFs in Illustrator, I have tried many times to explain to others within my workplace why that is a very bad idea, but it seems to fall on deaf ears
You can edit images in a PDF via setting up Acrobat properly so the image is opened from the PDF into Photoshop or whatever photo correction app you use. Make the changes there and when you save it, it saves the corrected image back into the PDF. This a perfectly accepted method of editing images in a PDF. Opening the PDF directly into Photoshop or Illustrator is NOT. Just keep the info that Gordo posted above in mind.
I second what Joe wrote in the previous post. It's possible to perform complicated image editings in PDFs, then print those documents successfully. You just have to be very careful. There are three possible obstacles I've encountered so far.
1. Rotated images aren't rotated anymore after editing. This can be due to the nature of PDF, where an object can be rotated just by attaching a 'rotation' value to it. Apparently the editing process does not retain this value.
2. An image, with an attached color profile will loose this color information after editing. Just like in point 1., the editing process will not preserve the original profile. The image will revert to some default color space like sRGB or SWOP after editing.
3. Flattened PDFs which have images cut to million slices are practically impossible to edit. So the best contenders to be edited are unflattened PDFs, which have their images intact.
I always make a proof print of the edited PDFs just to make sure they will behave well in the production afterwards.
I don't believe my coworker was editing the image itself. She was, rather, swapping in a new image to replace the original one. Since I would do this in InDesign, I frankly have no idea which Acrobat tool she used, nor if she actually "removed" the original versus just placing the new image on top of the old.
I should also mention that I work for a nonprofit with a publishing division. I am not a prepress technician and all this theoretical editing in Acrobat is happening after receiving designed files from a contractor and before sending anything to the printer. My coworker was attempting to make edits to the print PDF that was included with the InDesign package and so we wouldn't have been able to send the printer the full InDesign files to work with, which is our usual workflow. The most recent version would have been her edited PDF.
Thank you for this additional detail. As I said in my other comment, I work for a nonprofit with a publishing division and so I don't have the ability to proof print as you suggest. Which is all the more reason for me to discourage my coworker from making edits using Acrobat, in my opinion. Plus, she wasn't opening the image in Photoshop and editing it. She was somehow placing a new image on top (or instead) of an old image.
1. Not sure what version of Acrobat/Photoshop version you are using but the latest version of Acrobat DC and Photoshop images that are rotated retain that rotation after editing in Photoshop and saving back into Acrobat.
3. You can have Pitstop, if you have Pitstop, to combine those images back together. It can get to be a lot of work though so yes it is always best to keep PDF's unflattened.
If that is what she is doing then yes...she shouldn't be doing that.
So you have the Indesign package, but your co-worker edits the PDF sent with the package
Wait. You have the InDesign PACKAGE? That means you have the complete InDesign file with supporting images and fonts. Why wouldn't you be able to send the full InDesign files to the printer? Edits should be done to the source files only (when possible). Doing anything else is begging for disaster. What if the client has a major text revision? Now you have to go back and repeat image swaps/adjustment/edits. If you made the edits to the source images, just replace the InDesign file, update links, and you are done.
What if they make a type change in the PDF and then for some reason you are forced to go back to the InDesign file. That previous edit could be overlooked, and now you are reprinting.
Sure, I get PDFs created in Word and such that I need to open and correct photos to print well, but that is the exception.
Ignoring for a moment the communication hole with a customer and making sure they get what they expected.
My biggest issue with this is the job history trail. If you're modifying things on the "press" so to speak AND you don't clearly document exactly what was done then when the customer wants a "reorder" of the exact same thing (because they loved it) and there isn't a clear way to recreate it - that's a problem.
I avoid editing anything in a way that requires any one person to now be the only person who knows how to print that job especially if that information is now only stored in that person's head. No go.
Quoted for absolute truth. Re-runs should be smooth as hell.
If you want to edit images with pdf in acrobat XI then there are the tips where you can implement in tool: Use selection tool to select and use an image as a basic object
for editing an image open content editing and choose edit text and images, select resize handles and other positioning tool, use transform tool to change the image orientation, use crop tool to change the portion of image, select and replace new image if you want to do so , export that image for editing and instant updating in your pdf file.
Maybe I'm missing something. If you have InDesign and the original file, and I believe you said you do, make any changes there, throw out the existing PDF and make a new one. Seems pretty straight forward. Nothing else makes sense. You may have to tell your coworker to bug out.
If your workload is such that you have trouble finding time for edits. Well, that's a management problem. Your coworker apparently has time on her hands if she can screw about editing in Acrobat.
If you receive files from outside graphics people, why wouldn't they be making the changes and sending you a new PDF. I think I am missing something.
This. Make sure your open files and PDF's share the same content, if possible. Also: never provide printers open files (like InDesign packages). Send PDF/X files, that are checked and verified to GWG standards. I think it's not the printers reponsability to make pdf's from the clients or designers files.
