register
xmoles
Hi to all
How do i find register between sheet and reservation?
It's possible the weather hot and cool can affect to result?
I know need distortion but it's not possible for each job different
Thank's
Es imposible responder a tu pregunta sin saber de que tipo de maquina estas ablando, y que significa "reservation". Responde en ingles para que los demás entiendan.
Al
You can improve your relationship with the other PrintPlanet members by giving full information about what the problem turned out to be.
Al
Thank you for your help
You are friendly
I'm not understand your answer, all can't learn languages as you
Le decía que ya que encontró la solución a su problema, seria mas apreciado por esta comunidad, si la compartiera con nosotros.
Por los idiomas, simplemente crecí en dos países.
Al
Hi
The problem is spot uvi not registration which sheet
We insert distortion in polymer at 99,5 %
Thank you
