On an AB Dick you should be using a compressible blanket. Check to be sure that's what you have. It's generally stamped on the back of the blanket, or check your invoice. I wouldn't go crazy with patching cylinders until you check the simplest options.
It's quite normal for a blanket to sort of flatten out after you've used it for a few thousand impressions. Assuming your cylinder pressures are set properly, you can pack the blanket. Pack the blanket with something like a tissue paper. That's all that should be needed. I've seen people shoving 20 and even 70lb paper behind their blanket to solve this issue. Don't do that! If you have a pack of metal plates they are often separated with tissue paper. Use that. It's all you need. Or packing sheets can be ordered from your local supplier.
Use the pressure adjustment. Back it off when running envelopes or heavier paper. That's that little allen key hole that's just under the flywheel thing.
Keith
