Printshop2050
First time poster. Having a problem finding out how to replace the right hand side clamp connecting rod.
The Clamp Connecting Rods connect the Clamp to the Angle Levers (2 rods and 2 angle levers).
Our “right side” connecting rod needs to be replaced.
Has anyone had the ”thrilling“ adventure of replacing the “right side“ connecting rod?
The part that looks like a human bone with donuts at each end.
Can’t figure out how to remove the top part of the rod from the clamp (attached to the clamp).
And I’m guessing that removing the set screw on the bottom of the connecting rod (lower part that is connected to the angle lever) and removing the pin that hold the both parts together will allow the lower part to be freed.
Appeciate any insights that you may have.
Thank you.
Thank you.
