Ricoh Introduces a Plant-Based Ink targeted to graphics & packaging. The ink is a derivative of oil-based ink created for décor printing as part of Ricoh’s collaboration with German equipment manufacturer Olbrich. It was developed to deliver excellent rub resistance and set-off performance for corrugated brown & white boards, as well as carton board.
The plant oil component creates a sustainable & environmentally-friendly ink:
- Quick drying—heat is not required to fix or dry.
- The oil penetrates porous substrates leaving the pigment near the surface.
- Reduces energy consumption & eliminates the need for a drying system.
- Odor free with improved food compatibility—no monomers are used.
- Biodegradable—supports deinking.
- Non-water based—biocides are not required to keep the ink usable.
- Easier to clean & less likely to clog print heads as ‘open time’ is much longer.
- Enhanced jetting reliability, performance and printhead life.
- Low ink consumption—the same optical density is achievable using 50% less ink.
