LukeW,
Green Printer is using a 20/22 Shore Hardness soft metering roller sucessfully on a nearly identical press
dampening system --- WHY can't you ?
Regards, Alois
Alois, I'm afraid it's not that simple!
If I remember correctly our year model shino had the position of the No 1 ink form & water form changed slightly. And thinking back to conversations with the machine techs years ago they had a lot of issues trying to get them to run effectively (very sensitive to fountain solutions)
Also different size rollers in the dampening system, & likely different positioning.
I can say that I even tightened the metering roller to the point you couldn't go any further and it would still allow excessive fount to pass through the nip at one point or another during running, EG: a 1" portion would flood the rest fine.
Standard metering roller duro for this machine is 30 - 32 shore A, so perhaps the drop to 20 is too much.
I'm going to the 25 duro and these 20 duro can sit in the cupboard.
