NorwoodPress
So I have been using SRA3 Digituff 270micron on my Versant 280 for the past 3 years. Lately I can't seem to run it back through so it makes the sheet go back flat, always keeps dog earring on the edge. I've always ran the profile as film on between 350gsm-400gsm setting with the fuser temp at 0, as if I do it too low it doesn't print great. I have tried to manually bend the sheets by hand so they are not as curled. The de-curler module has never helped with curling. It always been best to run it back through the fuser to get it flat again. What substrate stocks do you use and settings? Do you get curling?
