color_prepress
Recently the CTP take long time load 510x400mm plate compare to last time. (The longest will be 1 minutes)
Normally when the CTP running other size of plate (let say 670x560mm) after that if next job is not this size, it will have to adjust according to plate size and then load it then punch then start imaging.
But now when putting 510x400mm size, it take quite long to adjust the size before it can start imaging. (I suspect it keep adjusting to correct plate size but fail then it auto retry again and again. Then the louder sound-I think is clamp keep open and close then adjust plate size again)
So far no error code out. After loading and imaging it, the next 510x400mm that it load will not have this problem(because the size correct already, it just punch hole, clamp it then start imaging.)
So far if I load other size such as 525x459mm, 650x550mm, 670x560mm, 1030x800mm.... and so on, none of these need to take that long to adjust, clamp, punch hole and load. Only face this problem for 510x400mm plate. Last time this size also don't have problem(for 9 years)until now.
Anyone can know what is the problem? Is that related to this plate 510x400mm which one edge of it a bit lighter cyan coating compare to other area which make the ctp cannot check out the correct size? or ctp sensor got problem for this size?
