Should they all be set including water in integrrated or segregated? also, the first 15 shts come ot clean then it starts to scum at lead edge then it slowly disappears?
Dampening or inking?
Adjust the rollers in integrated position. Ink-up and set the strip widths. Remove the Pan and chrome rollers before this and install them after you have adjusted the Z roller and the dampening form roller.
both ink and damp. So for both set in integrated? Also, what about the issue with starting out clean, then 15 or 20 shts in it tones up at lead edge then disapears? Thanks
Yes. set rollers in integrated position. The other issue might be the proper roller setting. update after resetting the rollers, if it still gets toning then there may be some other reasons.
