1st Problem faced: KOMORI Lıthrome 40 S, the problem is that on cyan inking rollers, the metal surface was bare and metal surface of the roller from half like cut with a knife,there was no cyan ink on half of the roller. When I checked that, the printer was using a soft drinking water.In water system with the conductivity of about 100 microsiemens. When we added some hardener then the problem is overed. If you say why only cyan unit, then I can say that as KOMORI users know that the inking rollers have copper on the surfaces and the cyan pigment (Pigment Blue 15:3) is made up of from the raw material cupperpthalocyanine. Both have cupper so this cupper is creating this strange problem when inner water is soft. If the reverse osmosis system there and by any how if hardener not added to the system the same problem could happen for KOMORI press.
2nd problem faced: When the heat set printer called me on saturday, he told me that all the balankets are piling up with water dust after 10000 copies which is a very short run for heat set printing and the subsrate was a coated LWC paper. When I checked the press, it was true all the blankets were piled up. After investigating, I found that from the reverse osmosis system, the processed water was coming into the technotrans system around 100-120 microsiemens, strangly that there was a control chart there and the operator was writing there the same numbers by declaning from 280-300 to 100-120. When I asked them they had this problem for a while. The hardener feeding pump was not working efficiently. The possible cause is that since the water is not rich with calcium so it is very agressive now and needs calcium to be satisfied to reach 300 micrrsiemens so looks for calcium and the main calcium source in the system is the paper surface. Whatever the paper type is, it pulls the paper surface and takes with it and excessive paper parts accumulates on the blanket wherever it is.
3rd problem faced:When a 2 press printing was done, they told me that the red areas are fluactuating and decreasing the red shade in some areas I saw that they were removing by separating with hand bad ones.I checked and found that the incoming water was tap water from ground and it was 2000 microsiemens,no reverse osmosis. The possible cause is that the excessive calcium which comes from tap water are accumulating on the inking rollers and especially on magenta (Pigment Red 57:1) unit the problem is a disaster. Why? since the magenta pigment is made up of calcium salt so that like pulls like then the calcium from the water comes there and pulls water to the surface of the rollers and rollers not transfer the ink anymore successively where calcium deposited.
Water treatment is so importatnt, it should have the hardness within certain limits. Hardeners by the way, should be added 0,5 % generally, 0,1 % hardener addes up to the conductivity about 50 microsiemens, one should consider that and treated water depending on the system effectivity up to maximum 50 microsiemens conductivity water terats so the 250 microsiemens comes out from hardener and maximum 50 from treated water tottally in generaly 300 microsiemens.
Best regards,
Engin
Best regards,
Engin
