Re: Spot varnish
Hello Deb, this should be a matter of turning on interactive trapping and the selecting the object desired. If the original object has a box around it then this is what the selection will be. It is possible your selection will need to be in some sort of clipping path, but it is hard to tell without seeing the actual pdf. If you have pitstop 7.x and acrobat pro v8 you can select the desired content for varnish and create it in acrobat instead, this is another option and will also tell you if the box is real or some other issue, either way you should know where the problem lies.
good luck
john
