Strike through Varnish/UV
Copper
Does anyone have any incite on running strike through Varnish with UV? Tips on how heavy to run the Varnish and how to balance the load temps with the UV application inline. Problem is Varnish does not like heat and running Varnish and UV at the same time with load tempts high causes the Varnish to try and brick. We aired the loads right away and saved them..but their has to be a trick to avoid the bricking affect. thanks
You need to use the correct pairing of varnish & coating and also be able to laydown powder as well. You could be running too much varnish?
