[email protected]
I've been using Suitcase 11.0.4 on the same G5 mac/10.4.11 for quite a while without issue. Recently, suitcase has become very slow after activating/deactivating fonts few times normally. That is, after login, suitcase is fine for a while - maybe 4 or 5 cycles of activating then it slows to crawl. Activating a single font will take 20 sec. Fonts are always located on a mounted volume but I get the same results when activating locally stored fonts.
Logging out and back in restores it to working order for a few cycles. I have re-installed Suitcase, tried it on other Admin user accounts and created an brand new Admin user acct. with same results. One thing that is also different and odd is the situation where if fonts located on a mounted server are activated and the machine shut down it would cause (the familiar) spotlight hang on restart. That no longer happens.
I have the feeling that I hit some crazy key combination and turned something on that I now cannot find to turn off because this behavior started suddenly one day without any apparent difficulties with Suitcase or the system. Any ideas?
Thanks, Dan
Thanks, Dan
