I'm finding that the image from our 52 has had a dot issue for quite some time. Close examination shows the dots are smeared, like tear-drop shape - falling in the direction of the grip edge. I know the press operator is quite green so far as running a 5-colour press, but he's all we have right now. It's been years since I've run a press, so I can't offer too much advice.
I know the press has had the packing adjusted on various units. I'm thinking there isn't equal diameters between the blanket and the plate.
I'm leaning more towards the blanket-plate relationship than blanket-impression cylinder, as the dot shape is consistent. One notable point is: some units produce a shorter image overall (marks can't reach the others for height), giving us a fit nightmare. Also, there are times where some units drag the dot into a line/geo-dot. This I attribute as far too much packing on the plate cylinder.
My question is: If the tear-drop shape "falls" towards the grip (pointed ends point toward the tail), is it the plate packing or the blanket packing that is too large? One cylinder has a surface speed greater then the other. Is the tear-drop shape made because the contact point flattens the dot and then drags (smears) it slightly to create the "point" on the tear-drop? Or is it the height of the ink that contacts the blanket first - dragging until the full dot makes contact?
Each scenario will produce the tear-drop, but in opposite directions. Am I looking at some other issue entirely?
