I touched upon this in another thread, but would enjoy a little feedback to the concept as we are approaching much more complex galaxies, such as the NanoSphere!
Help me out Gordo, Erik, Al. Anyone please comment.
See gentlemen, litho can be dramatically improved, by changing of the ink formula based on given coverage or take off for a given print form. This coverage factor is an everchanging variable.
The rigors that are put on an ink in very light to very heavy coverage are dramatically different. The idea would be to keep the same replenishment rate for each ink, regardless of coverage. More study would have to be done to find the ideal ink film thickness, say for each process color.Then, based on total percent covearge for that ink, that print form, the strength of that ink would be adjusted to accomodate the coverage. This would be ideal. If the inks and extender portion are formulated properly, you force constant replenishment based on take off. This would allow your ink to run at a constant state of proper micro emulsification, without adjustment to the dampeners. Ink stability in the train, ink setting and drying would be improved and much more predictable.
The design needed on press to achieve this is reachable. If you have 4 Full Strength process inks dispensed from pumps, that would be the ink used for a full coverage, 100% solid sheet. With the inks, you would have a let down extender also designed to be pumped and mixed for each changing print form. Knowing the exact total coverage for each color, the ink would be pumped and mixed with the proper amount of let down extender to maintain constant ink film thickness and constant replenishment. This is an ideal situation to take litho closer to science, although it shall always remain an art.
COVERAGE, is the most important factor and the one thing that presently cannot be controlled. The example of an ink system as just described, would control a major variable not yet properly explored or developed.
Your thoughts are encouraged. Thank you. D
