Ret Heidelberg Instructor
In the early 80's I worked for a packaging outfit that was using a UV application on Detergent Packaging. They ran UV Varnish into the ink fountain and through the ink train on a 5 color 60" Meihle. Looking back on it now I woiuld say it was a pretty bad method of applying UV. They used metal relief plates to to transfer the varnish onto the blanket in the last unit and then it hit the UV lights to get cured. It worked, but it was messy had an obnoxious order that stays with you and was dangerous. Back then people were not aware of the dangers of the chemicals in the UV varnish and what long term exposure to the varnish and the UV lamps could do to their health. You cannot get away with this crap today although some places still do. You are better of with a dedicated unit that is properly configured and ventilated that is in-line, or as previous contributors stated get a dedicated unit and do your coating off-line.
