Upgrading digital and other equipment
Wow, okay you have a lot to deal with. Rather than looking at multiple levels of equipment for different purposes, perhaps you should do a breakdown of your existing work and the percentages of demand in relation to the equipment. Rather than buying equipment to cover all of the possible types of work you have, you should focus on your core printing and use external trade houses for the specialty items such as NCR. Cutters are great, however, very expensive to maintain. Slitters and blades are not cheap. A decent guillotine would do all of that for you. In regards to minimum cut size. Stick with what you can do and get your clients to fit your limitations. For business cards under a certain size, you can make a cutting block out of card stock. For example. Business card at 50mm is too small for the gauge, create a cutting block at 100mm and set you final cut at 150mm. As long as it clears the guillotine clamp plate, you will be good to go. Keep your overheads low so if you get a drop in work, you dont have high lease payments and or cash in the bank. A lot of problems are created by designers who create artwork outside of basic industry standards, and print shops are trying to cover all demands. It not sustainable for small print shops.
We used to have to reprint stuff cut wrong, especially business cards, usually the stack didn't get pushed back in the guillotine cutter and then the whole stack was messed up. We use it for bleed trimming, greeting cards, postcards (bleed) and tons of business cards. With your preset jobs it is wonderful, and truly load and walk away. It did come with some templates, but I prefer to use the wizard feature and the step by step and save jobs for reuse. Takes some patience and a few wasted sheets to set up, I haven't been able to train my one staff, she gives up, but that is how she handles most new things, and she did not pay attention during the training. She just uses the jobs I create, hasn't worked well for her when I am on vacation. I think it is easy to setup.
I've learned it takes a certain mindset to understand these machines. I got frustrated with my first few employees that were unable to master it. It seems simple to me but I think if you're brain can't do it, it can't do it. I had one employee that mastered it after about 8 months but that seems like soo long compared to the like 2 days it took me to understand the machine. <shrug>
Thank you for your input!
Hi MIE,
You're right, a lot going on right now. The equipment I'm looking at is a necessity, other than the Duplo. We print a lot of envelopes and NCR so I need to be able to do those in house cost effectively, without an offset press. We have already rigged the guillotine to cut 2", but the back stop is slightly askew and when we press the blade buttons it jumps a bit, or hesitates. That tells me something electronic is starting to go. I can get someone from 2 hours away to make adjustments / repairs, but they are the same ones who moved it in and set it up in the first place. I have no other options within 4 hours. We also make do or rig up other old equipment to perf and score, and we do a lot of that too. I think 1) I would rather not frustrate my awesome and hard working employees with antiquated equipment 2) I prefer to be pro active instead of reactive 3) I am under the impression that the more you bundle in the contract, the better the pricing. I agree that keeping the overhead down is important, but payroll is the biggest expense and if we can work more efficiently, we can do more with less employees.
Hi MIE,
I totally understand. Have you considered a small offset. They are easy to operate and take very little training for the sort of work you are talking about. I dont envy your situation. The problem with digital finishing equipment is that in most instances, they are light weight construction and dont go the distance. An outlay on an offset press, even a 10-20 older press will last for another 20 years if you look after it. Ryobi is a good brand.
@MIE I wouldn't imagine there are many (any?) digital printers looking to venture into offset nowadays. There's so many reasons not to do that - the need for a skilled press operator, chemicals, rags, space, etc. when you can sub out decent volumes so cheaply nowadays.. and if the job isn't decent volume, you can run it cost effectively on a fast, modern digital press. For any digital printer looking to diversify, there are many ways to invest and add value to your service portfolio, but offset really isn't one of them.
Regarding finishing equipment, if you buy industry standard professional equipment, it's far from light weight and will last 20 years+ if looked after and serviced.
I have 2 very old offset presses that need to retire, and there are no pressman in this area. Another shop and I have been looking for a long time. That's why we're going all digital now.
Last year I purchased a relatively small print shop. It's time to upgrade the equipment and that is not my fortay.
Currently we have Ricohs, a Pro 7100s and a 4501. Neither is supported for NCR or window envelopes, and anything smaller than a #10 needs to be opened first (personally I find that easier than closing them when done). We have had to outsource larger NCR and window envelope jobs - not cost effective. Then again, opening and closing envelopes in house isn't cost effective either. I have recently been running NCR on my current machines, but Ricoh has made it clear that they won't cover repairs caused by NCR if I continue.
I was looking at a Ricoh 7210x and a Canon C910. Ricoh says the C910 can't compare to the 7210 - so they are now proposing a C5310s. I think the 7210 is a better comparison, but price wise they can't compete with Canon.
I have been trying to weigh all the differences to determine what I need, including the Efi Fiery options, which booklet maker, etc. I want to grow the business but funds are tight.
I also NEED a Duplo to cut/score/perf because my finishing equipment is on it's last leg and my cutter doesn't work right.
I think getting an iJet would be a good solution for printing window and regular envelopes. Both the C910 and the 7210 support NCR printing.
I'm thinking of keeping the 7100 - even though it will be out of contract - as my back up machine, and for laser safe letterhead (the Canon is not laser safe on some office printers).
Does anyone have any opinions on the Ricoh 7210, 5310 or Canon C910? The iJet or Duplu?
Does anyone have a method to determine the best equipment investment? This is daunting and I don't want to make the wrong choices. Thank you in advance!
I work for a dealership that sells Ricoh, Canon, Shap. The imagepress is a good machine, it's only rated for 167,000 a month. We figure it's a step below the 7200 in volume. The two machines make different looking prints as well. The Canon has more gloss, the ricoh is more flat. I would say your print volume and personal preference in color should be your deciding factors. If I were you, I'd shop and see which you like best. Both have strong points
Duplo and fiery are now sharing a template to make it easier. I've seen it on the Ricoh, but I've just seen fiery updates on canon for the same feature
