Using Insite to Upload Impositions
yespress
Is there a way to upload a .job or .pjtf file in Insite and have it import into the job. In Insite I noticed that only the "Refine" and "Workflow" process templates show up, but not the "Import" process templates. Is there a way to get these to show up in Insite?
If you have RBA you may be able to write a rule to import after upload.
You can also use BusinessLink to export an imposition from your MIS system directly into Prinergy.
