Mike the Print Man
Just did this video and thought I would share. Let me know what you think, if you find something like this useful or not.
Thanks.
Thanks.
That was one reason why I suggested using linked InDesign files instead of doing the design work directly in the "Master" file. Plus, in the example I gave in the video, the customer would supply us with InDesign files already, so there was no need to copy all the work they already did, I would just import their copy. Thanks for watching.I love this idea, but definitely have multiple copies hidden away in case someone screws it up or it gets corrupted. I lose about one file EVERY month from ID crashing and corrupting a file.
If anyone has many clients using the same materials with small changes...
Something along OP lines that I use for my real estate agents at my company is a modular approach with PDFs.
When i produce the monthly newsletter, individual agents will use it to promote themselves. The bulk of the newsletter is common, so those pages/portions are PDFs that update automatically across the dozen of agent-specific newsletters we mail out. My predecessor would copy and page each piece to the agent-specific file, which was very time consuming and created more opportunities for error.
DesignMerge Pro also creates PDF/VT.Further information about PDF/VT can be found at the PDF Association's website at <PDF Association publishes PDF/VT Application Notes showcasing the benefits for variable data print streams – PDF Association> with samples of XMPie PDF/VT-1 files at <Cal Poly Graphic Communications PDF/VT Test File Suite 0.1 – PDF Association> (I personally put together these samples using InDesign and XMPie uDirect with assistance of a group of fourth-year (senior) students from CalPoly San Luis Obispo's Graphic Communications department.
- Dov
