Variable Data stalls on Fiery
Go to a windows explorer screen (The file folder icon) and type %temp% in the search bar. Everything that shows up delete. Those are temp files that need removed. Next, look at the partition size EFI gives you. Almost nothing compared on your working side that needs space for ripping a job. Completely lopsided. Have your software output a different file other than pdf, like ppml. It will rip 10 times faster. Just check a single sheet before you print the entire job. When we were using Fusion Pro we had issues with transparency and ppml. Also if using pdf make sure it is pdf\vt they tend to rip faster..... Sometimes!
Thanks for the suggestions. I will look into those.
Right now we can't output PPML, we'd have to move up to a newer version of our software, which we will likely do. I'll also look into PSL Page Builder. Thx for the info.
