This setting should slow the engine down to about half speed but no change occurs when turning the feature on. On the Versant 80 I had a NVM that I would enter to put the engine in skip pitch mode.
Ink Setoff Prevention Mode should be able to be set from the control panel under Tools, Other Settings, Ink Setoff Prevention with the options of Off, Always On or On For Required Paper Only. It also appears on the Fiery under Finishing with the same options as on the control panel. I’ve tried setting on both the control panel and the Fiery and I can’t slow the engine down. They have no effect whatsoever.
Has anyone been able to successfully use this feature? I don’t have a problem with the stacks becoming bricks from toner sticking sheets together but I would like to at least try to slow the engine when I have jobs that may need to be slowed down or at least try to see if cooling the sheets off before they get duplexed would lengthen the 2nd BTR life. Any suggestions would be appreciated.
