Web-based monitor calibration?
Hopkins Printing
Although I realize that a spectrophotometer is best way to calibrate a monitor, I am wondering if there a way to calibrate a monitor over the internet. I have seen a website or two that offers a basic calibration via a series of questions in conjunction with basic adjustments to brightness and contrast (among other adjustments).
Does anyone use anything like this? Thoughts and/or site suggestions?
Thanks,
Jon
I don't know of any such sites, but here is one idea for how such a sight could take some subjectivity out of such a process:
1. The site would display some RGB patches.
2. The user would do screen captures of the patches.
3. The user would open the captures in Photoshop, take appropriate RGB readings, and jot down values.
4. The user would input those values into a suitable online form at the site, and the site would respond with suggested adjustments.
5. Repeated cycles of 1 - 4 would home in on a "calibrated" monitor state.
Note that in step 3 the appearance of the patches is evaluated by Photoshop, not the user, and would reflect on the monitor's display performance at the time of the screen capture in each iterative cycle.
This is just of the top of my head, which for some reason feels a little pointed today.
Al
I just thought of a way of cutting the website out of the picture. Just have Photoshop on your own computer display the RGB patches, and proceed with steps 2 - 5 as above on your own.
That seems too simple. There must be some thing wrong with it. Any one find the flaw in it?
Al
suggestion - but your mileage may vary
<!--snip--!>
Monitor calibration and gamma
( Hi Jon - long time ! )
Michael Jahn
Application Support Specialist
Compose Systems Inc, USA.
4740 Northgate Blvd. Suite 100
Sacramento, CA 95834
Tel: (916) 920-3838 ext 102
Fax: (916) 923-6776
Email: [email protected]
Web: Welcome to Compose!
Adobe Photoshop ? For the price, you could buy a ColorMunki
I can't think of a single reason of what Photoshop would do to help you evaluate or calibrate a monitor.
I just wanted to add that here.
@ Stephen Marsh - yes, that is an excellent one !
Hi Michael,
I can't disagree with you on the high price of my suggestion, but I was simply assuming that the OP would already have this ubiquitous piece of gear.
However, can you please comment further on the merit of my off the cuff idea? If the screen capture software does not introduce color shifts of it's own, would it not be capturing the subject monitor's display of known RGB values? If so, then measuring these observed values in Photoshop would yield information on the monitor's color shifts, no?
Now, how and where to use this new information in a corrective fashion is another matter.
Thanks,
Al
um, well, no, not really.
No. "if the screen capture does not introduce color shifts..." is already heading down a horrible path - it is not the screen capture application, it is more a 'what is being used to display an image' problem.
just open this web site in as many browsers as you have installed ( I have Apple Safari, Google Chrome, Microsoft Internet Explorer, Mozzila Firefox, Opera's Opera )
Is your system V4-ready?
You need to first understand that each application may - or may not - modify images on their way to the screen - if that is the case, each time you screen capture, you may be changing the file.
Here is another issue - round tripping is not possible.
OK, those are good crits. I like them. But let's imagine for a moment that we had a screen capture app that did not introduce a shift. Isn't Photoshop the proper non shifting display companion app for this exercise?
So if we had the ideal shift free capture app and a display app with the capability to measure, such as Photoshop, then why would round tripping not be possible???
Thanks,
Al
You'd need to take a photo of the screen on a calibrated camera and then use RAW in photoshop to get the colors, but then you need to add correction for ambient light.
"Screen capture" by a piece of s/w running on the same computer won't do anything to help you calibrate. The RGB values are the same no matter how you adjust the actual screen settings.
They can be adjusted at the driver level, the graphics card may have h/w adjustments (via settings) then the monitor itself will have the same adjustments.
Building a website that claims to calibrate your monitor could make a very good 1 Apr joke, actually :)))
Hi Jon,
Not sure this helps, but Eizo sells a line of monitors with automated color calibration using a device that swings down out of the housing of the monitor. The calibration is independent of a computer platform and can run cal checks by the number of hours or on a calendar basis. I realize this is not a solution for those who have monitors in place, buit it may be one going forward.
I saw this monitor at the Color Management Conference, however, I'm no display expert so the value of that feature would have to be weighed against it's ability to properly calibrate the display. I'll leave that question to folks like you.
Introduction:
Monitor calibration is based on the following:
1) Building unique look up table for the video card - Assists in creating linear gray balance as well as targeting colors within the monitor's gamut
2) Brightness Normalization - Specific to a room's brightness and image representation (brighter for brightly lit rooms, brighter for web purposes, darker for print simulation or darker for a dimly lit room)
3) Contrast - Usually 2.2 Gamma or L* for those who critically judge contrast steps
4) ICC Profile - When used in combination with the above 3 calibrations, will produce the best viewing result - IF - the image software calls the ICC profile into use. (Many internet browsers do not. Photoshop and other pieces of the Adobe Creative Suite do.)
Calibration and profiling can use either a spectrophotometer or a colorimeter.
A spectro sometimes reads too many samples and then the software errors in its averaging algorithms. A less expensive colorimeter will typically produce equal or sometimes even better results. (more info on request)
Several high end displays have built in colorimeters and will calibrate remotely upon an administrator's instruction. This is also true of the medical field where doctors view results - but typically do not perform their hardware calibration.
Using that concept, inexpensive colorimeters could be purchased and periodically placed over a monitor for a Java based web app to communicate with.
At the end of the day, who cares if it is web based, or local - considering that the real cost is in the colorimeter?
Summary: Real monitor calibration and profile building requires a device more sensitive than human vision. The human eye is too adaptive to change for vision to be part of a critical color calibration system.
Web Calibration
Web Calibration
I was also checking the dates on this post - dangerously close to April 1st. zetaprints is of course correct, Al Ferrari just isn't thinking straight - no adjustment of the monitor controls will affect the screen grab. Turning the monitor off will still give the same screen grab! But Apple's OSX monitor calibration could work in a similar way using a web site.
OSX asks the user to evaluate several test images and uses this to set up the monitor so that shadows are not too dark and and all steps in a grey scale are discernible. The Gamma is adjusted with a full range photo and colour casts evaluated by comparison.
It's a rough and ready method and I would guess something similar could be transferred to a web site.
Hi all,
I remembered old debate in another forum where I mentioned the surprisingly good result of Supercal program. And yes, it still says the result is comparable to using some "less good" devices (I will not mention, of course:). So see for yourself, I think it's a pretty good program ...
http://www.bergdesign.com/supercal/
P.S: Mac only, sorry :)
Best regards
Kamil Tresnak, Prague
Without a measurement of the emissive output of the screen, this seems like an exercise in futility. If accuracy is even remotely important, even MacGyver would spring for an i1 display.
Good point Meddington :)
OK, i1 is not on my list of "hated" devices :)
But just for sure, did you tried this sw? ... trust me, you will be surprised. We are not discussing if measuring is importatnt, this is without debate, but original post was in "just curious ..." style.
Sure, there are several disadvantages, but trust me, you will be suprised with result.
Best regards
K.
Hi, everyone
Keep it simple, cause otherwise we will come to real monitor calibration.
Claim - you do not give any warranty on such calibration method
------------ simple idea
Just put on screen some grey and CMYK patches with descriptions
There MUST be -
Grey patches in at least 25,50,75% side by side (or similar)
light and dark CMYK patches (with text - you have to see them and to see difference)
Some human photos
Some different well known colors - like Milka, Coca-cola etc
Some error situations (wrong grey balance, cannot see 95% of Cyan etc) and instructions how to adjust monitor if something is wrong (some small videos would be fine)
All this you can put in one screen
!!! make sure show this in RGB and make on-screen proof in RGB, otherwise diffferent settings can cause different results (you have to convert CMYK->RGB before post on screen proof otherwise you need Serendipity, Dalim or similar s/w)
When customer makes all this according to instructions and acceptable for his eyes - monitor WILL NOT BE CALIBRATED, but atleast they will not miss important things.
** just my some unprofessional thoughts
Forget one more thing - tell about right profiles in right places. This helps a lot as well :)
You can split instructions by "dummy" and "wizard". My thoughts is something between them.
Seek thee Lab mode, and have your hopes dashed
Photoshop is dependent on your color settings to display values, yes ? Can you work in Black and White properly ? I would believe in the Easter Bunny and the tooth fairy far before I would believe Photoshop for 'numbers' used for calibration !
Are you familiar with Lab mode in Photoshop ?- i think we need to start there to help you understand a few basic problems...
from Iliah Borg...
B/w image in Lab
http://pics.livejournal.com/sail2ithaki/pic/0003rgzp
Just L channel made visible, brightness/contrast are wrong
http://pics.livejournal.com/sail2ithaki/pic/0003shgf
Same, but with Lstar profile set as the grey working space
http://pics.livejournal.com/sail2ithaki/pic/0003xd7w
Same, but with Color Preferences closed, brightness/contrast are right
http://pics.livejournal.com/sail2ithaki/pic/0003y2rg
Dropping to ridiculously low gamma grey, all is wrong
http://pics.livejournal.com/sail2ithaki/pic/0003wpqf
Switching on Show Color Channels in Color
http://pics.livejournal.com/sail2ithaki/pic/00041sfs
L channel with grey profile set to ridiculous and Show Channels in Color switched on, brightness/contrast are right.
http://pics.livejournal.com/sail2ithaki/pic/00043428
Here is a comment (about the above) from a the Color Theory group (by Jacob Rus)
it’s quite unfortunate that (at least as far as I know) there’s
no way to get Photoshop’s gray working space to be similar to L*. [For
me, the “other” item in the selector menu for gray working space in
the color settings is grayed out.] The "Gray gamma 2.2" space is
somewhat lighter but not entirely dissimilar, and "Dot Gain 30%" has
similar average lightness, but has more contrast in the midtones and
correspondingly less in the highs and lows (like an "s-shaped curve").
I set my working spaces up as sRGB, GRACoL, Gray Gamma 2.2, and then
just mostly work in CIELAB space.
It seems pretty silly to me that viewing a single channel at once as
grayscale always shows it as if the content was in the current gray
working space, when in CIELAB mode the obvious "right thing" to do is
show L* as L*. Alas. I guess they want to masks &c. in the same space,
and for such it's not quite as clear to me what the best choice is.
Display as Gray Gamma 2.2 works just fine for me there; any choice of
gray working space would probably be fine for showing
masks/selections/etc.
Zeta is right, the RGB screen capture will be the image your video card sees, not what the monitor displays.
