What is the best price you have seen on 12x18 12pt C2s?
I am getting ready to do a lot of postcards on our KM6501 and was wondering how low of a price is possible if you buy paper in bulk, multiple pallets full at a time? I am looking to settle on a 12x18 stock that will run well on the KM6501 (a digital paper I suppose) that is between 10pt and 12pt.
If you buy enough at a time, is it possible to get the price down to $.06 per sheet? Or am I dreaming? Anyone with any experience at this?
We are mainly a book manufacture and use +1mil 20x26 10 and 12 pt a year cut down 12pt is about $0.0667 a sheet for 18v12 or 19x13. I run the offset sheets right off the skid in a xerox242 19x13 and 18x12 and never have had a problem. The mill said the offset skid was the same as the digital. I often laminate the book covers and still no problem. Also no problems when not protecting the covers, other than normal wear and tear. Our stock is FSC certified which carries a larger cwt, but so does digital paper.
I don't know how much paper you buy a year, but I doubt you'll get a $ 0.06 a sheet going the digital paper route.
You should be able to buy 25x38 10pt for around $200/1000. You would have to cut to 12x18 from there. At 200/ 1000 it will not be very white but should copy fine.
Affordable paper
Affordable paper
Most paper merchants have clearance items every month, check with your sales rep to find some 19" x 25" - 10pt and you can cut it down to 18" x 12" which is the correct grain direction for digital. Sometimes we pay as low as 5c/sheet. Some merchants will even cut the paper for you and charge you a flat fee of $25-$100 depending on the quantity you order
Ian
