On certain halftone images, I am seeing very faint light lines (as in slightly less ink in these areas) down the length of the print. The lines correspond to the grippers on the impression cylinder. What would be the cause of this? And more importantly, is there anything I can do to remedy it?
I'm running a hamada 611CD duplicator press, laserplates.
Thanks!
This is a long shot but maybe related.
When you said that these faint lines correspond to the grippers, I started to think of a phenomena that some researchers call Mechanical Ghosting. It is not the normal mechanical ghosting that we think of that is due to the form rollers and plate interaction but these researchers use the term mechanical ghosting for a phenomena in a blanket to blanket web press, where the image of the one blanket will affect the image of the other blanket with a ghost.
For interest here is a link: Gordon might like a new reference to this term.
www.fpc.fi/uploads/files/Ghosting_eng_1.pdf
So how might this be related to your problem?
I think the mechanical ghosting on the web press is due to differences in the rate or force of release of the web from the blanket surface due to image coverage and web wrap geometry. Anyhow that is my best guess so far.
With your problem, it may be that the rate and/or force of release of the sheet from the blanket is slightly different in line with the grippers. This them might make the bands, which is somewhat like the ghost in the web press but without an image doing it.
If this is related to the problem, then what can you do about it? Not sure but maybe stiffer paper, or less stiff paper. Lower tack ink. Lower speed. Different blanket.
Is your problem also related to the type of image you are printing? Lots of coverage etc.?
As I said, its a long shot. Good luck.
