Jayhawkmike
This is a question for general commercial printers, although it could apply to anyone reproducing material.
New print project. You receive documents from the client. You do not know the designer. They send you native application documents with all supporting files. They also send a PDF file that conforms to what you would consider "ready for press". You have never had a conversation with this client about what type of file you would receive. Which do you use? Do you call and ask? Suppose the print buyer uses outside source (freelance designer two States away, etc.) and the buyer really doesn't understand/care which you use. They just need to see a proof! ASAP!
I would like to use the PDF file. It checks out great! Designer obviously knew what they were doing when creating and used Instant PDF or preflighted it out of Pitstop, etc. This is the obvious answer for speed and reliability. I drop it in my workflow, trap, impose, proof, and I'm done!
However, what if there is a correction cycle that would dictates you need the native files? Ah, now we have the opportunity to proof the same job with two different files! The InDesign file may not proof the same way as the PDF.
Curious to see if anyone else sees this dilemma and how they resolve it.
