Standard Finishing
4OverXerox
Announcement
Collapse
No announcement yet.
Correction Pen for Kodak Thermal Direct Plates
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Correction Pen for Kodak Thermal Direct Plates
    Hello All,
    Can anyone tell me which correction pen to use on Kodak Thermal Direct plates? I have tried just about any correction pen we have (from the old days with standard CTF plates), but none of them work.
    Anyone?
  • #2
    Re: Correction Pen for Kodak Thermal Direct Plates
    Hello,
    Kodaks European Customer information manual says:
    deletion pens:
    Ultrachem one touch deletion pen
    Pacific Chemical image remover CTP #4
    I can' t tell you for the States, however.
    Regards
    Comment
    • #3
      Hello Hans-Juergen,
      Thanks for your info. I contacted our supplier (Tetterode Holland), and they would contact Kodak to try and order the pen you mentioned. I hope this one works!
      Thanks again!
      Kind Regards... from Holland.
      Comment
      • #4
        We have been having the same problem with deletion pens on the Kodak Sword Excel plates. None of our vendors came up with one that worked well or didn't dry out after a few uses. Our press operators use blanket fix or the stuff thats use to strip paint / varnish off of wood. It usually takes two applications to completely remove the image. In the plate room I use plate developer. I put a drop on image I want to remove and let it sit for 10 min or more then repeat again if needed.
        Comment
        • #5
          What about Kodak Gold plates, are there any deletions pens that will work with them?
          Comment
          • #6
            Corr-Quick was recent find
            They work well on our positive CTP plates
            see attachment
            Comment
            • #7
              > {quote:title=Fatboysmart wrote:}{quote}
              > Hello All,
              > Anyone?
              I got some information from a contact @ Kodak RE: Touching up TD's.... We've used the deletion pens w/ great success for a while, just recently had an issue that required an addition (and ordered a set of addition pens, however, we haven't used them yet).
              +Here is the information:+
              +Thermal Direct non process plates+
              +Additions - Kodak Aqua Image addition pen+
              +Deletions+
              +Baseline CTP-#CTP-1000+
              +ITW Marktex metal plate image remover #2201+
              +A-1 deletion pen U.N. 1760 - Maple Leaf Associates, LLC+
              +Short-term plate storage+
              +Kodak Aqua Image plate cleaner / preserver+
              - Mac
              Edited by: Mac on Oct 9, 2007 6:14 PM
              Comment
              • #8
                Originally posted by mjwagner73
                I know this is a little late but we have always used "Corr-Quick" image remover pens. They work for positive and negative plates. They worked great with the Kodak Sword plates. We now use Kodak Trillian plates and these pens work great with them as well. I hope you have one that works for you!
                A little late? Eleven years? ROTFL.
                But good advice is always appreciated!
                Comment
                • #9
                  The correct term is "necropost".
                  Comment
                  4OverCanonKBAAvantiXeroxSmartsoft (Presswise)DuploAMSEnfocus
                  Free Download
                  Collapse
                  Trade Show Survey=
                  Instant October Trade Show Survey
                  Come On! Only 5 Questions
                  PRINT 19 and PRINTING United are squaring off in October.
                  Will you be at one of them?
                  Both? Neither?
                  Please take our 1-Minute survey to tell us about your plans for the two big fall shows!
                  Take The Survey.
                  CanonXeroxSmartsoft (Presswise)DuploAvantiGraph Expo4OverKBAAMSAvantiEnfocusGraph Expo
                  What's Going On
                  Collapse
                  There are currently 3369 users online. 54 members and 3315 guests.
                  Most users ever online was 6,855 at 12:33 PM on 06-06-2019.
                  Working...
                  X
