Adding adhesive sealing strip to prints
neondawg
Need a bit of advice hopefully someone can help me out.
I just had a request for 160000 z-folder mailers with a adhesive sealing strip on the top. Can anyone suggest a cost effective way to do this or a paper supplyer that has 24lb bond with a seak strip already on it
Thanks,
Yonu
We use a local screen printer to apply re-moistenable glue. If you need peel & seal, that's a whole lot more complicated.
There are finishers who have machines to apply peel & seal strips to prints....otherwise screen printers for re-moistenable as above.
I am sure remoistenable would work i will check around some screwn printers in the area and see howuch it would run
thank yall
Yonu
thank yall
Yonu
What did you end up doing on this if I may ask and was USPS ok with it sealing with a strip rather than glue dots?
