Adding default paper to the fiery dropdown
Louiscamp
I've created a paper type and want to add it so it shows in the drop down for expert setting when I'm printing this stock. I'm missing a step as I can't get it to show in the drop down box. Can anyone point me in the right direction?
Lou
If you are running FS100 or later system software, when you first calibrate using that stock (under General > Tools > Calibration), you are prompted to enter a name for it; the procedure then swings into setting up an output profile associated with your calibration settings. And once you have that output profile, it will show up in the drop down box as you wish.
