Adding offset to a shop
AP90
hey guys, was wanting to get a discussion going about this. We are a digital only shop and are doing pretty well. We also have a few consistent monthly jobs that we have to outsource to offset. They’re simply too large for digital any way you slice it. I’m total we pay about 10k/month outsourcing. These are magazine jobs. Is there any way with a 10k/month budget we could begin to produce the work ourselves? We get plenty of request for offset size jobs, we just can’t land them because of having to outsource them.
Would it be reasonable to run offset booklet jobs on a 20” press? Or is a 29” minimum needed? If we dug in and found out that we could dive in we would probably start with a tower booklet system. Maybe add squarespine to eliminate the problem of thick booklets on tower systems. Also, I’m not talking a bright and shiny new Heidelberg. I’m talking something in good used condition. I know I’d have a pressman cost too. I just feel that if we had the capabilities ourselves, we could land a lot more jobs and easily double our monthly offset spending/profits. It’s just hard to know if it’s possible when I can’t find out what actual cost of things are. I can find paper cost, but much past that and it’s hard to find. Would love to hear the input.
majklcze
welcome in offset world! Please remember that it is investment, and not only investment of money... But if you enter into this industry, it is great challenge. First, you should consider what are your budget, what is your target customer and what is your target products.
In my opinion, I would not spent time with smaller format than B2 (29"?) because smaller offset machines are still more and more obsolete...
Please remember that you will need a lot more machines and items such as CTP, B2/B1 cutter, foiling machine, consumables and software etc... And offset requies much more space.
We are running on this machines without any problems, I think they are on good price in used condition on the market: CTP - Python Highwater (low chemical process), Manroland R205E (expensive!, you can use cheaper B2 machine, but 5 colors are great advantage), Duplo DC 10/60 (have option with square fold).
I would recomend press with CIP3 ink presetting, it is a must have!
AP90
KBA 74 Karat with coater - minimal investment, minimal waste, compact size, no CTP, no ink keys.
Ive actually seen these, but I believe they didn't get very good reviews. I love the concept of them. Im not sure why no one ever tried a larger format DI press. Seems like theres a lot of magazine runs between 4k and 10k that these would be good for.
mutti8000
Hello APO90,
Simple - KBA 74 Karat "A" flawed concept! stay with Conventional Offset Printing.
Regards
Hello Alois
Could you please tell us more on what you think is flawed with this concept?
I know from your other posts that you seem to have great technical insight, so please tell us more!
I would agree that the concept has it's limitations, but you have to put it all into perspective.
IMHO the reason why it was a big flop was: Printers not understanding the concept, machine way too expensive, akward feeeder location, lack of competent technicians. amongst others.
Nowadays you can almost get these machines for free, and they will produce high quality commercial work if operated probably, but beware if you hire a offset operator with traditional offset background, they are not able to get their head around the concepts and they get very frustrated not being able to adjust the color on machine.
We switched from one 1998 traditional 4-color to two 74Karat w. varnish and still had money to spare, wouldn't go back to traditional offset.
Alois Senefelder
Hello mutti8000,
You broadly answered, the many reservations regarding KBA Karat. BUT my main concern is the use of an Anilox Roller.
Regards, Alois
I know I'm Late to the Party, but here's what I have on my ACTUAL RUNNING EXPERIENCE with the Karat 74 presses. I've been running then since 2008, so I have over 10 years of experience. Our first one was a 2000 non coater press, refurbished by KBA (originally a red press, repainted blue in refurbish), and installed by them. 2 week training with a KBA tech (I ran a QMID 46 before this press) , so I was already familiar with the direct image to plate tech. Ran that press HARD!!! There were electrical issues here and there, had a couple contactors- heavy duty relays- crap out-I replaced those, had the Baumuller Power Drive (Controls power distribution to rotate the plate cylinder motors for imaging independently, or the main drive for printing a job) crapped out too. It had a bad solder connection on a 24 volt pin that I repaired. Had a chiller that sprung a leak in the Condenser, so I had to pretty much disassemble the whole chiller to put in a new condenser. That thing is about 7 feet tall. Also had to replace the pull fan for the chiller. My work had a POS IR dryer that was installed in the press. It was essentially 15 1000 watt halogen bulbs in an array that would get so hot that they would burn out the contact tips from powder contamination and melt the holders for the tips. I replaced all the holders and tips, but when I did I put small washers behind all the tips to spread the heat and reset it to the correct distance for the bulbs. Also I put silver conductive grease on the bulb terminal ends to keep power out and have a better electrical connection. Worked great after. Had a water pump for the main circulation go out- that one was under warranty, and had replaced most of the water pumps for controlling temps on the annilox rollers and the valves to allow flow.
The 2nd KBA 74 Karat is a 2004 coater press that the company sent me out to demo to see if we should get it. They sent me to Texas (we are In Arizona) to check out a coater press. The guy starts up the press, gets into start up, and the computer restarts. After it restarted and stayed on I knew what the problem was when I looked at the Window screen clock. The time was wrong (In the press dialog it shows you errors by time that they occur) It was a bad CMOS battery that didn't have current time so it got confused and restarted the computer. I Went in to the CMOS and set time and date for the demo, and there was no restart- so I knew it was just the battery. With the demo I wanted to see how to set the coater up, and how to tear it down. We got that press in 2016, replaced our non coater with it, I did most of the rewiring myself. The non coater went to pasture for parts. BTW some parts are compatible between the 2 models, some aren't.
BTW 3~ months after the coater press was installed- they gave me a job that they wanted to have soft touch coated. Man, I wasn't trained in this- I only saw it that one time. I KILLED IT!!
SO- Karat 74's do have some electrical issues from time to time, I do my own press diagnosing, most repairs, and printing to boot. - And I know where the parts are
Now on to the weirdness of the internals of these presses- for starts- if you get a non converted press- Presstek is no longer producing the original plates for this press. Verico is now dealing with the plate manufacturing, the plates are thinner aluminum, so you have to have a thicker foil on the plate cylinder to make up the distance to be able to image. Use to be a Presstek pearl dry 74, but now you have to go with a Zahara K74. With this press you have to have the right height of the plate on the cylinder for it to burn in properly. Even a little crap ( last job was picking) that fell in under the plate distorts it so that area isn't at the proper height for imaging. Then you have to remove the plate, clean the cylinder, load another plate, and reimage. Some of the boards in the Operating system(in the computer encloser) for Imaging- KBA wants about $10,000 to replace those. I've seen the boards they have sent out when trying to figure out an issue we had before and there were wires hot glued in place on the back sides of the board, and I was never a board issue that I had.
Keep your annilox rollers clean, fresh ink and new blades in your heads, and your cams and chains lubed up- then your half way there.
Also anyone that needs Karat 74 info- Just Email me - micahmcg@gmail.com
