chevalier
Perhaps I made an assumption at some point or was misinformed. I'm being painfully diligent in identifying my steps however mundane. Questions/comments are the bottom.
I open an Illustrator file provided to me...
"Your current settings honor CMYK profiles in linked content but profiles were set to be ignored when this document was created." <Cancel> <Continue>
<Continue>
"Missing Profile"
"What would you like to do?"
<Leave as is (don't color manage)>
<Assign current working space: GRACoL2006_Coated1v2>
<Assign Profile: [drop down list of profiles]>
"Could not find the linked file "blahblah.psd". Choose Replace to select another file or Ignore to leave the link unchanged.
<Apply to all>
<Replace>
<Ignore>
<Cancel
<Replace>
I point Illustrator to the missing links(s).
Illustrator is now happy and ready to operate. I perform my preflight tasks - this does not include me relinking or editing the linked Photoshop file. I open said link in Photoshop and it has a "U.S. Web Coated (SWOP) v2" embeded profile. I close without modification or saving leaving the file in-tact.
<File>
<Save As...>
<Format: Adobe Illustrator (ai)>
<Save>
"Illustrator Options"
"Version"
<Illustrator CS5>
"Subset fonts when percent of characters used is less than:"
<100%>
<Create PDF Compatible File>
<Include Linked files> - NOT SELECTED
<Embed ICC Profiles>
<Use Compression>
OK
<File>
<Save A Copy...>
<Format: Adobe PDF (pdf)>
<Save>
"Save Adobe PDF"
<Adobe PDF Preset: [drop down list of profiles]>
[PDF/X-4:2008
<Save PDF>
Now the problem...
That linked SWOP image was converted to GRACoL via ACE with Black Point Compensation. I know this only because I had another lot that came in via PDF that required zero modification. The same image printed differently. I checked the builds and found that the differences were perfectly congruent to a conversion in Photoshop to GRACoL via ACE with BPC.
Why?/How?
What could I have done differently to prevent this?
<Continue>
"Missing Profile"
<Apply to all>
<Replace>
<Ignore>
<Cancel
<Replace>
<File>
<Save As...>
<Save>
"Version"
<Illustrator CS5>
<100%>
<Use Compression>
OK
<File>
<Save A Copy...>
<Save>
"Save Adobe PDF"
[PDF/X-4:2008
<Save PDF>
Now the problem...
Why?/How?
